# Upload to Box With the File Browser
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "has_image , End User , Overview , Article , Product Utilization , Box Web Application , Established"}} />
While browsing all files and folders in Box, uploading a new file or folder is straightforward:
1. In the **Files** section, select **New +** button in the upper-right corner.
     <img src="https://mintcdn.com/product-docs/VZLIcIGDdKj92oYw/images/box-fundamentals/new-plus-button.png?fit=max&auto=format&n=VZLIcIGDdKj92oYw&q=85&s=89c5dd1362a69795cac900b92d49066e" alt="new-plus-button-png" width="251" height="127" data-path="images/box-fundamentals/new-plus-button.png" />
2. Select **File Upload** or **Folder Upload**, depending on what you'd like to upload.
3. Select the file(s) or folder you'd like to upload.
4. You can select multiple files for upload by holding the **Command** or **Control** key (Mac or Windows, respectively) while selecting files. However, you can only select one folder at a time for upload.
5. Select **Open** or **Upload**.
If your session is interrupted, Box allows you to later resume uploads of files that are over 100 MB in size using the Uploads Manager. The Uploads Manager appears at the bottom of the screen when you start uploading files or folders.
**To resume an interrupted upload:**
* In the Uploads Manager header click **Resume All**,
  or
* In the Uploads Manager click **Resume**.
  <img src="https://mintcdn.com/product-docs/6Q7nCk1JXzHqPpg6/images/box-fundamentals/uploads-manager-resume-button.png?fit=max&auto=format&n=6Q7nCk1JXzHqPpg6&q=85&s=43215500d33de7ea7604975a58d88198" alt="Uploads Manager showing failed uploads with Resume All button highlighted." width="1362" height="326" data-path="images/box-fundamentals/uploads-manager-resume-button.png" />
**To cancel a current upload:**
1. In the **Uploading** dialog window, select **Cancel All**.  Box displays the **Cancel All Uploads** dialog window.
2. In the **Cancel All Uploads** dialog window, select **Cancel All**.
  If you are having trouble uploading files, here are some possible issues and solutions:
  * [Troubleshooting Uploads to Box](https://support.box.com/hc/en-us/articles/360044196773-Troubleshooting-Uploads-to-Box)
  * [The upload button is greyed out and not working](https://support.box.com/hc/en-us/articles/360044192993-New-and-Upload-Buttons-are-Greyed-Out-and-Not-Working)
