# Drag and Drop Files into Box
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "has_image , End User , Overview , Article , Product Utilization , Box Web Application , Established"}} />
You can drag files from your desktop to the **Files** page in Box. Your files will be uploaded and will appear in the folder where you dropped them.
When you're on the go, you can [use drag-and-drop on iPad](/en/box-mobile/box-for-ios/using-ios-drag-and-drop) to upload to Box.
  <img src="https://mintcdn.com/product-docs/R4fhSza8L0hjDmrn/images/box-fundamentals/Drag_Drop_New.png?fit=max&auto=format&n=R4fhSza8L0hjDmrn&q=85&s=ca2733e27b409ae1fea2f8dfe8d11194" alt="Drag_Drop_New.png" width="819" height="431" data-path="images/box-fundamentals/Drag_Drop_New.png" />
  **Note:**
  * Dragging and dropping entire folders is supported only in Chrome, Firefox, Microsoft Edge, and Safari. For other browsers, use the File Browser or Box Drive.
