# Download Files and Folders from Box
    display: "inline-block",
    verticalAlign: "middle",
    height: height,
    width: "auto",
    margin: "0"
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "has_image , End User , Download , Article , Product Utilization , Box Web Application , Established , Instruction"}} />
### To Download a Single File:
* Click next to a file's name to select it. The action toolbar will appear above your files in the top-right.
* Click the download icon  <InlineImage src="/images/box-fundamentals/Download_icon.png" alt="Download_icon.png" />  to begin the download process.
### To Download Multiple Items:
* **Shift**+click on multiple items to select them. The action toolbar will appear above your files in the top-right.
* To select all items, press the key combination **Ctrl**+**a**.
* Click **Download** to begin the download process. Your selected items will be downloaded together in a single zip file.
<Tip>
  **Tip:**
  If pressing the key combination **Ctrl**+**a** doesn't select all items:
  1. Clear the current selections.
  2. Scroll to the top of the listed items and let the display update.
  3. Slowly scroll down, allowing each screenful of text to update before scrolling further.
  4. When you reach the bottom of the list, press the key combination **Ctr**l+**a**.
</Tip>
