# Using the Dispositions page
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "End User , Overview , Article , Product Utilization , Established"}} />
The Dispositions page is only available if [access has been granted](/en/box-admin-tools/box-admin-reference/enterprise-settings-content-sharing-tab#trash).
If available, **Dispositions** can be selected by clicking **More** in the sidebar menu from within Box.
The Dispositions page contains:
* All active, non-trashed, files under retention policy
* The disposition date for the most recent file version (i.e. when the retention policy governing the files will expire and a [disposition action](/en/box-admin-tools/box-admin-reference/governance-settings#disposition-action) will be executed at the end of retention)
The list contains all files that the user owns or collaborates on. It shows files based on their most recent version, with expiration based on the winning policy (i.e. the policy with the longest duration) that has been enabled by the admin in [Governance Settings](/en/box-admin-tools/box-admin-reference/governance-settings).
<Warning>
  The list of expiring files is updated daily, i.e. bulk updates to the list are done once a day. This means there might be small discrepancies, such as if a file falls under a conflicting retention policy between data calculations. It may take up to 72 hours until changes are reflected on the page.
</Warning>
Manual file extensions are immediately reflected in the list. File name changes and updated date changes are reflected after refreshing the page.
  After turning on the disposition page setting for at least one person, Box will start processing your enterprise's data. It can take up to 72 hours until the data starts to display.
  We prioritize the processing of files expiring in the next 12 months, then asynchronously process content expiring further in the future. This may lead to a situation where content expiring further in the future gradually displays in the subsequent days after enablement.
Files within the Dispositions page can be:
* Extended (if you are an owner or co-owner, and the admin has [enabled the required policy](/en/box-admin-tools/box-admin-reference/governance-settings#disposition-action) setting)
  * If the policy doesn’t allow for an extension or if a user is not an owner or co-owner, the extend button will be disabled
<h2 id="extend-the-disposition-date">
  Extend the disposition date
</h2>
Owners and co-owners of files can extend the disposition date if your admin has [enabled the required policy setting](/en/box-admin-tools/box-admin-reference/governance-settings#disposition-action). To extend the disposition date:
If an admin has [enabled the required policy setting,](/en/box-admin-tools/box-admin-reference/governance-settings#disposition-action) owners and co-owners of a folder can extend the disposition date of files contained within it. Up to 20 files at a time can be selected.
### Extend the disposition date for one file
1. From the sidebar, select **...More**, then **Dispositions**.
2. Hover over the file whose disposition date you want to extend.
3. Select the clock icon.
4. Select how long you want to extend the disposition date by. Options include 7 days, 30 days, or 1 year.
### Extend the disposition date for multiple files
2. Hover over the files whose disposition dates you want to extend.
3. Select the files you want to extend.
4. Select **Extend** from the top of the page.
5. Choose how long you want to extend the disposition date by. Options include 7 days, 30 days, or 1 year.
  If a maximum extension length is configured, users cannot extend a file beyond that limit. In those cases, the **Extend** button will be disabled and users will see a tooltip explaining the maximum limit was reached.
  For example: if the policy allows a maximum extension of 6 months and the file has already been extended by 2 months, a request to extend it by 1 year will only add 4 more months, reaching the 6-month limit.
An exclamation mark on the list indicates the file is governed by a policy which doesn’t allow for extension. Whether a file’s disposition date can be extended also depends on the winning policy settings, where the ‘winning’ policy is the one with the longest duration. If a shorter policy allows for extensions but a longer (winning) policy doesn’t, the user will not be able to extend the disposition date.
