# Using Metadata
    display: "inline-block",
    verticalAlign: "middle",
    height: height,
    width: "auto",
    margin: "0"
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "Metadata , has_image , Overview , Article , New , Product Utilization"}} />
You and your Box application have at least one thing in common: You both rely on metadata. Metadata defines and stores custom information associated with your files in Box. This custom information can serve many different use cases. You can set it either within the Box web application or programmatically via the API.
To optimize metadata searching, use the [Metadata Query API or Search API](https://developer.box.com/guides/search/) to filter results based on metadata templates and attributes. Additionally, metadata also provides the opportunity for companies to migrate metadata from existing systems to Box. Therefore, if you had a homegrown document management tool with custom metadata, you could now map those values to Box so that you do not lose any of your legacy data.
This article serves as a guide on how to use metadata within the Box web application. For technical details on how to integrate with Box, developers can visit our [API documentation](https://developer.box.com/guides/metadata/quick-start/).
## Metadata Templates
The primary way to use metadata is through metadata templates. Templates are a logical grouping of metadata attributes that help classify content. For example, a marketing team at a retail organization may have a Brand Asset template that defines a piece of content in more detail. This Brand Asset template may have attributes like "Line", "Category", "Height (px)", "Width (px)", or "Marketing Approved".
Metadata templates are important for several reasons:
* To enforce uniformity across your enterprise's metadata
* To reduce errors and accelerate data entry by your employees or team members
* To enable advanced searches
When using metadata, it is important to consider what functional groups will benefit from adding and maintaining metadata templates. Our suggestion is to consider using metadata in the following lines of business:
* **Legal** - Classifying legal contracts. From custom terms of service to acquisition contracts, metadata attributes like signature date or contract term can prove useful for discovery.
* **Vendor Management** - Onboard and manage vendor contracts and details for much easier reporting and cost management.
* **Sales** - Organize content by product line, use case, or sales geography. Make it easier for sales representatives to find important collateral.
* **Marketing** - Manage digital assets and sales enablement material. Centralize multiple digital asset repositories to help streamline brand efforts.
* **Project Management** - Add structure and status to documents. Add detail to project work plans to help accelerate and communicate project progress.
* **HR** - Standardize the employee lifecycle, from hiring to retiring. Leverage metadata to find common forms and analyze employee data.
## Using Metadata Templates
Here are the basics for using metadata templates.
### Applying Metadata Templates
**To apply a metadata template:**
1. Click the file to which you want to add Metadata.
2. In the file's preview screen, click the Metadata icon in the right-hand side-bar.
3. Next to **Metadata**, click **Add**, then choose the Metadata template you would like to use.
     <img src="https://mintcdn.com/product-docs/FFgx8Ia-ECpN-LGR/images/box-fundamentals/metadata-template-image01.png?fit=max&auto=format&n=FFgx8Ia-ECpN-LGR&q=85&s=299beea550eebe7754c543d2c498514c" alt="metadata-template-image01-png" width="886" height="1024" data-path="images/box-fundamentals/metadata-template-image01.png" />
<h4 id="custom-metadata">
  Custom Metadata
</h4>
If no relevant metadata template exists, you can create a custom template for a particular file. When choosing a template, select **Add Custom Metadata**. Click **Add Attribute** to create a custom attribute. You'll be prompted to enter a "Key", or title for the attribute, and set a value for the attribute. Once you are done, click **Save**. You can add as many custom attributes as you need. These additional attributes are not shared across any other files.
  **Note:** You can assign up to 100 metadata templates to a specific item.
### Editing Metadata Values
**To edit metadata values:**
1. Click the metadata instance you want to edit. Box displays a pencil icon to the right of the template's name.
2. Click the pencil icon. Box displays the attribute values in text entry boxes.
3. Click the attribute value you want to edit.
4. Edit the attribute's value.
5. Click **Save**.
  **Note:** While editing a saved **custom** instance, you can still add attributes by clicking **+**.
### Autofilling Metadata in Templates
With this feature enabled, Box account holders in E-Advanced accounts can use Box AI to extract Metadata from supported file types, such as .pdf, .tiff, .png, .jpeg, that have one or more attached Metadata templates, and automatically add that Metadata, as suggested values, into the Metadata template.
Box provides two metadata extraction agents for autofilling metadata templates: **Standard** and **Enhanced**.  Both extraction agents use Large Language Model (LLM) processing to extract contextual data.
<table border="1" cellspacing="0" cellpadding="0">
  <tbody>
    <tr>
      <td><span> </span></td>
      <td><strong><span>Standard Extraction Agent</span></strong></td>
      <td><strong><span>Enhanced Extraction Agent</span></strong></td>
    </tr>
    <tr>
      <td><strong><span>Underlying LLM characteristics</span></strong></td>
      <td><span>Default: Gemini 2.0 Flash (standard model) non-reasoning models with single LLM calls           </span></td>
      <td><span>Default: Gemini 2.5 Pro (premium model) reasoning models with chain-of-thought prompting</span></td>
    </tr>
    <tr>
      <td><strong><span>Model flexibility</span></strong></td>
      <td><span>CYOM via API (standard or premium model)</span></td>
      <td><span>Default model only: no choice to change model</span></td>
    </tr>
    <tr>
      <td><strong><span>Best suited for</span></strong></td>
      <td>
        <ul>
          <li>Structured or semi-structures documents</li>
          <li>Documents of less than fifty pages, with fewer than twenty extraction fields</li>
          <li>High-volume simple extraction tasks.</li>
        </ul>
      </td>
      <td>
        <ul>
          <li>Complex and unstructured documents</li>
          <li>Documents of more than fifty pages, with more than twenty extraction fields</li>
          <li>Advanced use cases requiring deep insight and precision</li>
        </ul>
      </td>
    </tr>
    <tr>
      <td><strong><span>Data extracted</span></strong></td>
      <td>
        <ul>
          <li>Text</li>
          <li>Dateline</li>
          <li>Number</li>
          <li>Multiselect</li>
          <li>Small taxonomies of less than 200 nodes</li>
          <li>OCR for English, Japanese, Chinese, Korean, and Cyrillic documents</li>
          <li>Can extract metadata from up to 25 files</li>
        </ul>
      </td>
      <td>
        <ul>
          <li>Text</li>
          <li>Dateline</li>
          <li>Number</li>
        </ul>
      </td>
    </tr>
    <tr>
      <td><strong><span>Accuracy on generic documents and contracts</span></strong></td>
      <td><span>78%</span></td>
      <td><span>85%</span></td>
    </tr>
  </tbody>
</table>
#### For Box Admins
If you are a Box admin, you can enable and disable this feature.
**To enable or disable autofilling metadata for your enterprise:**
1. In your Admin Console, click **Box AI**.
2. Click **Enable Box AI for documents** and toggle to the desired state. Disabling **Box AI for documents** also disables the question-and-answer feature for documents in Box Preview. To learn more about Box AI for documents, see [this article](/en/box-ai/getting-started/box-ai-for-documents).
#### For Box Account Holders
If you are a Box account holder and your enterprise's Box admin has enabled the Autofill Metadata feature, Box enables you to use Box AI to automatically add the file’s Metadata, as suggested values, into the file's metadata templates.
**To autofill metadata from a file:**
1. In your**Files** window, double-click on a file that has at least one Metadata template. Box opens the file in the Preview window.
2. In the Preview window's sidebar, click the **Metadata** icon.
3. In the Metadata panel, click **Autofill**.  Box displays the metadata extraction agents available to your organization's account.
4. Click a metadata extraction agent.
  <img src="https://mintcdn.com/product-docs/FFgx8Ia-ECpN-LGR/images/box-fundamentals/metadata-autofill-button.png?fit=max&auto=format&n=FFgx8Ia-ECpN-LGR&q=85&s=34c821d223e2040caafaa04a38fd2e30" alt="metadata-autofill-button-png" width="318" height="401" data-path="images/box-fundamentals/metadata-autofill-button.png" />
Box AI extracts relevant information and adds it as suggestions in the metadata template's input fields. In the metadata template, Box highlights values suggested by Box AI.
  <img src="https://mintcdn.com/product-docs/FFgx8Ia-ECpN-LGR/images/box-fundamentals/metadata-suggested-values.png?fit=max&auto=format&n=FFgx8Ia-ECpN-LGR&q=85&s=24b18fea91ca9b4c273526ff09c12285" alt="metadata-suggested-values-png" width="887" height="1024" data-path="images/box-fundamentals/metadata-suggested-values.png" />
After reviewing these suggested values, you can save or change them. To save them, click **Save**.  To change a suggested value, type a new value in the field.
### Deleting Metadata
**To delete a metadata instance from a file:**
1. Click the metadata instance you want to delete. Box displays a pencil icon to the right of the instance's name.
3. In the bottom of the pane, click **Delete**.
     <img src="https://mintcdn.com/product-docs/iPwbarrlsv1nexQc/images/box-fundamentals/delete-metadata-01.png?fit=max&auto=format&n=iPwbarrlsv1nexQc&q=85&s=0a221bc3790d83f742e3a81cba06238a" alt="delete-metadata-01-png" width="789" height="1024" data-path="images/box-fundamentals/delete-metadata-01.png" />
4. In the deletion confirmation window, type the metadata template's name then click **Confirm**.
**Note**
Deleting metadata is a permanent action you cannot undo. No trash bin exists for recovering deleted metadata. Further, if a metadata template or attribute is associated with an active retention policy, you cannot delete the template, attribute, or options until you have [deleted the retention policy](/en/box-governance/retention/deleting-a-retention-policy).
### Using Advanced Search With Metadata Templates
Metadata values are indexed by the Box search engine. If you perform a search, the search engine treats metadata values similarly to how file titles or file text are currently treated. If a match on metadata is made, it will influence the search results returned to you using Box’s custom search relevance algorithm.
You can also use **advanced search** to filter results within specific metadata templates.
**To search using specific metadata templates:**
1. Click the **Advanced Search** icon <InlineImage src="/images/box-fundamentals/filter-icon.png" alt="filter-icon-png" /> in the **Search** box at the top of the screen.
2. Click **Metadata** and select the template you want to use for your search.
3. Enter the values you want to search for, then hit enter to search.
### Creating Templates
Administrators can create and manage templates from the Admin Console.
For more information, see [Customizing Metadata Templates](/en/box-admin-tools/managing-content/metadata/customizing-metadata-templates) as well as [How to Create the Right Metadata Structure for your Enterprise.](/en/box-admin-tools/how-to-guides-for-admins/how-to-create-the-right-metadata-structure-for-your-enterprise)
### FAQ
Here are some frequently asked questions and answers about metadata:
#### **How do I add templates to my enterprise?**
Admins can create metadata templates from their Admin Console, by navigating to **Content** > **Metadata** tab.
#### **Can I use metadata without templates?**
Yes, you can use metadata without templates. For accounts that have metadata activated, you can always add metadata in the Custom Metadata section of metadata.
#### **What types of accounts can access metadata?**
Metadata is a feature reserved for Business Plus, Enterprise, Enterprise Plus, and Enterprise Advanced accounts.  It is also available on developer accounts through [https://developers.box.com.](https://developers.box.com) To upgrade your account, please contact your Box account team.
#### **How does metadata work with external collaborators within a folder?**
Metadata is available only for external collaborators who collaborate in a folder, where the folder owner has enabled metadata on their account.
Read and write access of existing instances adheres to standard folder collaborator settings. New instances can be applied only by users within an enterprise via the web application; external collaborators outside the enterprise are not able to add instances to a file via the web application.
The metadata template owner enterprise owns the metadata template and all values of the template. If the metadata template changes, this affects any values of metadata that are collaborated with external collaborators.
#### **How does metadata work with folder permissions?**
Metadata adheres to folder-level permissions. A collaborator with permission to view items, can view metadata, and a collaborator with upload permissions can edit metadata values.  For example, if a collaborator is a viewer in a folder, that person is able only to view metadata and not edit it.
If a collaborator is a previewer uploader in a folder, then that person can both view and edit metadata. [Refer to the permissions chart to see which permissions are granted to each collaborator role](/en/box-fundamentals/for-users/collaborating/collaborating-by-inviting-others/understanding-collaborator-permission-levels).
#### **How does metadata work with shared links?**
[Refer to shared links chart here](/en/box-fundamentals/for-users/collaborating/using-shared-links/creating-shared-links).
#### **Is my metadata encrypted?**
Yes.
#### **Are there any known limitations?**
Metadata is not deleted unless a user deletes the metadata directly off the item. If an account activates and deactivates the metadata feature, or if an item with metadata is deleted, metadata is still retained.
