# Sort Files and Folders
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "has_image , End User , Overview , Organize , Sort , Article , Product Utilization , Established"}} />
You can sort your files and folders by Name, Date Modified, and Size. Simply click the appropriate header to sort.
Click the squares icon to show the files in a grid image format. Click the lines icon to show the files in a list format.
When you define a sorting order in your**Files** window, Box applies that sorting order as the default sorting order in all your Box windows.
  <img src="https://mintcdn.com/product-docs/FFgx8Ia-ECpN-LGR/images/box-fundamentals/screen-shot-2018-01-22-at-3-13-36-pm.png?fit=max&auto=format&n=FFgx8Ia-ECpN-LGR&q=85&s=f19fb0aa0bc044ccbf066493c0f0a037" alt="screen-shot-2018-01-22-at-3-13-36-pm-png" width="975" height="191" data-path="images/box-fundamentals/screen-shot-2018-01-22-at-3-13-36-pm.png" />
For numbered files that go into double digits (or higher), "0" must be used to fill digit spaces for the numbers to display correctly. For example, if you have a list of items that goes to 15, use "01" instead of "1" for the order to display correctly.
