# Creating Bookmarks
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "User , End User , Overview , Mac , Bookmarks , Article , New , Product Utilization"}} />
You can save any webpage to Box as a **bookmark**, helping you organize and quickly access the web-based content you visit most often. You can also use bookmarks as quick links to content for which you only have "viewer" permissions
## **To create a bookmark:**
* Click the **New** button found in the upper-right corner of the page. Select **Bookmark.**
    <img src="https://mintcdn.com/product-docs/hv7V6Xeed9krubib/images/box-fundamentals/p3qy467wjv0w3ja922n1rycv3yhx0n4d.png?fit=max&auto=format&n=hv7V6Xeed9krubib&q=85&s=f8e909c3b5de0a9efe0a58782e126f1d" width="2496" height="949" data-path="images/box-fundamentals/p3qy467wjv0w3ja922n1rycv3yhx0n4d.png" />
* A pop-up window will appear prompting you to enter the URL you wish to bookmark, and a name for your new bookmark. A description is optional.
* Click **Create** to complete the process.
Your bookmark will appear in the folder you are currently viewing. Clicking it will open the page in a new tab.
**Limitations:**
* Bookmarks cannot be synced as [Box Sync and Box Drive ignore web-based documents](https://support.box.com/hc/en-us/articles/360044195433).
* The bookmarked URL cannot exceed 500 characters.
