# Adding Descriptions to Folders and Files
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "has_image , End User , Content Management , Instructions , Article , Product Utilization , Box Web Application , Established , Instruction"}} />
A **Description** can be added to Folders or Files on the Box Web Application, as long as **you have Editor access** in the folder. 255 characters is the maximum character limit for the Description field.
## **Folder:**
1. Click the folder (do not open the folder).
2. In the right pane under Details, you will see the Description where you can enter or modify a description.
  <img src="https://mintcdn.com/product-docs/Qyy8LmrN0pVKQFf5/images/box-fundamentals/fo.png?fit=max&auto=format&n=Qyy8LmrN0pVKQFf5&q=85&s=72b996e0d0f395f7456229da9ef60daf" alt="fo-png" width="998" height="267" data-path="images/box-fundamentals/fo.png" />
## **File:**
1. Click the file (do not Preview the file).
  <img src="https://mintcdn.com/product-docs/eGmBsXsUAf1Xqd2d/images/box-fundamentals/file-preview-description-sidebar.png?fit=max&auto=format&n=eGmBsXsUAf1Xqd2d&q=85&s=d222b348c03a93fd4338cd3d361e1eaa" alt="Box folder view with Details pane showing Enter a description field." width="999" height="160" data-path="images/box-fundamentals/file-preview-description-sidebar.png" />
