# Installing and Updating Box Drive
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "drive , has_image , Box Drive , End User , Overview , install , Article , Product Utilization , Established , P1"}} />
  **Note** Box does not support having both Box Sync and Box Drive installed on your machine, and there are [known issues](https://support.box.com/hc/en-us/articles/360043696454) with this configuration. Box Drive includes a Sync uninstaller; you can just install Box Drive and follow any prompts. There is no need first to uninstall Sync separately. [More details on uninstalling Box Sync](/en/box-drive/getting-started-with-box-drive/uninstalling-box-sync-using-box-drive).
## Mac
Prerequisites:
* [Supported OS version](https://support.box.com/hc/en-us/articles/360043696234-Understand-the-Box-Policy-For-Browser-And-OS-Support)
* Box Sync is **not** installed
Recommended minimum system specifications:
* 1.6GHz dual core processor
* 4GB of RAM
  **Note**: If your machine does not meet the recommended system specifications, you may still be able to install and run Box Drive. However, you may encounter a degraded experience.
### To install Box Drive on macOS:
1. [Download the Box Drive installer](https://www.box.com/resources/downloads/drive).
2. Navigate to the location where you saved the file, then, double-click it. The installer starts.
3. When prompted, select **Install for all users of this computer** and click **Continue**.
4. **DO NOT** change the install location. Click \*\*Install.
     <img src="https://mintcdn.com/product-docs/s-271m0kwdd6XjvM/images/box-drive/macos-installation-window.png?fit=max&auto=format&n=s-271m0kwdd6XjvM&q=85&s=641055df6842d8dfc84852e5c9ead3e3" alt="macos-installation-window-png" width="1464" height="1112" data-path="images/box-drive/macos-installation-window.png" />
5. The system displays a notification when the installation completes. Click **Close**.
6. Box Drive launches.
You must log in to Box Drive the first time you open it. (You may be redirected to your company's login page.)
After you log in, Box Drive displays a brief walkthrough of its features. When this is complete, your Box content is available at \~/Box
## Windows
Prerequisites:
* [Universal CRT](https://support.microsoft.com/en-us/help/2999226/update-for-universal-c-runtime-in-windows)
* [.NET Framework 4.8, or higher](https://github.com/Microsoft/dotnet/blob/main/releases/README.md)
* 4GB of RAM
  **Note**: If your machine does not meet the recommended system specifications listed above, you may still be able to install and run Box Drive. However, you may encounter a degraded experience.
### To install Box Drive on Windows:
2. Navigate to the location where you downloaded the file, and double-click it to run the installer.
3. Follow the instructions to complete the installation. If Box Drive does not launch automatically when the installation completes, you may need to go to the **Start** menu and launch the application manually.
4. You must log in to Box Drive the first time you open it. You may be redirected to your company's login page.
5. After you log in, Box Drive displays a brief walkthrough of its features. When this completes, your Box content is available at C:\Users\USERNAME\Box.
## Signing In
### Mac
After installation, Box Drive prompts you to sign in. You may be redirected to your company's login page.
After you log in, Box Drive displays a new Finder window. **Box** should display in the Finder sidebar, under **Locations**.
### Windows
Box Drive runs automatically after it is installed. You can also open it from the **Start** menu.
To start using Box Drive, simply sign in to Box at the prompt. You may be redirected to your company's login page. After you launch Box Drive for the first time, you can access Box from either the **File Explorer** or the Windows system tray.
### Logging out / switching accounts
To log out from Drive, click the Box Drive icon in your system tray (Windows) or menu bar (macOS). With the search window open, click the gear icon and then click **Logout**.
  **Note**: Logging out completely removes all traces of your Drive usage from your machine and enables you to log in again as a new user. Also, when you log out, your Box Drive session ends and the login screen displays. In addition, logging out of Box Drive deletes all of the downloaded content you had marked for offline availability. This clears up hard disk space on your device. This also returns to an online-only state all of the content you have marked for offline availability, and you must repeat the process of marking folders for offline availability.
## Updating Box Drive
It is important always to update as soon as possible to ensure you are taking advantage of the latest features and also that you are on the most stable version.
## Updating on Mac
When an update becomes available, Drive displays a system notification to inform you, and also adds a badge to the Box icon in your menu bar.
  <img src="https://mintcdn.com/product-docs/s-271m0kwdd6XjvM/images/box-drive/update-drive-1.png?fit=max&auto=format&n=s-271m0kwdd6XjvM&q=85&s=3f2e6288981c28108acdda53e2c4ce2c" alt="update-drive-1-png" width="999" height="345" data-path="images/box-drive/update-drive-1.png" />
1. To install the update, in the system notification, click **Update Now**. If you have closed the notification or missed it, you can navigate to the search menu by clicking the Box icon in your menu bar or by using the keyboard shortcut **Ctrl + Option + Cmd + Space**.
2. From the search menu, begin the update either by clicking **Update Available** or by clicking the gear icon and then clicking **Update**. Box Drive then prompts you to close any open Box Drive files and proceed with the update.
Box Drive can also auto-update when it launches. If Drive detects that an update is available while it is starting up, it automatically applies the update without requiring any action on your part.
## Updating on Windows
  <img src="https://mintcdn.com/product-docs/eEZ2SZ8FKaSHD273/images/box-drive/update-drive-2.png?fit=max&auto=format&n=eEZ2SZ8FKaSHD273&q=85&s=efa20f0c9f690e9792a1fc096ba5e40a" alt="update-drive-2-png" width="999" height="462" data-path="images/box-drive/update-drive-2.png" />
1. To install the update, in your system tray, click the Box icon to display the search menu, or use the keyboard shortcut **Ctrl + Alt + Shift + B**.
## Critical Updates
In some cases, updates are marked as critical if they contain key new features or important stability and bug fixes. Box Drive reminds you every day to update any new critical version to ensure you get the best experience.
  <img src="https://mintcdn.com/product-docs/eEZ2SZ8FKaSHD273/images/box-drive/updatemethods-callouts-windows-1.png?fit=max&auto=format&n=eEZ2SZ8FKaSHD273&q=85&s=32f4e2cba4f5107ce7b15866feaed6fa" alt="updatemethods-callouts-windows-1-png" width="999" height="462" data-path="images/box-drive/updatemethods-callouts-windows-1.png" />
