# Connecting AI apps to Box Drive
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "End User , Box Drive , Box AI , Article , Instruction , Product Utilization , New , P1"}} />
## Why connect your AI apps?
Connecting your AI agents gives your agents the connectivity and collaboration benefits from using Box Drive.
Box Drive holds a wealth of knowledge across the files you store in it. When an AI app can read that content, you get to insights and actions faster. An agent can draft a presentation, build a spreadsheet, or answer questions about a project, all grounded in your Box content. This article covers two ways to make that connection: pointing an app at a Box Drive folder on your computer, and connecting the app directly to Box.
In this article, we will cover a few examples of how to connect your AI apps to Box Drive.
## Pointing an AI app at a Box Drive folder
You can give your agent access to folders in Box Drive for it to work in for a session. The agent will then be able to comb through the files in your given directory to use as context for your workflows.
**Windows Users**
For those on Windows, moving to the new Windows architecture for Box Drive improves how Box Drive interacts with local applications that read and write files directly on your device, including local agents. The new architecture ensures Box Drive behaves similarly to a standard local drive, so your agents can reliably utilize Box Drive. If you are not already on the new architecture, follow the steps here to opt into the new architecture.
**Getting Started**
In setting up a workflow, applications typically allow you to scope the directory in which the agent will get its context from. With Box Drive set up, the specific folders on Box Drive can be selected as the working directory for the agent, which will allow it to sift through content on your Box Drive to retrieve information, work on files, and more.
The examples below use a folder named *Acme* in Box Drive that contains files such as *Q4 2025 Results.pptx*.
  <img src="https://mintcdn.com/product-docs/7_nzZaLyTjJmOCwG/images/box-drive/file-explorer.png?fit=max&auto=format&n=7_nzZaLyTjJmOCwG&q=85&s=e9bb3912b934a3868d90d5a6f78b8181" alt="The Acme folder open in Finder, listing Box Drive files including Q4 2025 Results.pptx" width="773" height="212" data-path="images/box-drive/file-explorer.png" />
### ChatGPT
1. In ChatGPT, select **Choose project**.
  <img src="https://mintcdn.com/product-docs/btkdJYIDqx2Q38jk/images/box-drive/chatgpt-box-window.png?fit=max&auto=format&n=btkdJYIDqx2Q38jk&q=85&s=e10e8803de06e9e423c28d3f2991d799" alt="The ChatGPT composer with the Choose project button below the message box" width="989" height="352" data-path="images/box-drive/chatgpt-box-window.png" />
2. From the menu that displays, select **New project**.
  <img src="https://mintcdn.com/product-docs/7_nzZaLyTjJmOCwG/images/box-drive/options.png?fit=max&auto=format&n=7_nzZaLyTjJmOCwG&q=85&s=8868bc03dcc78776883304554ac051e7" alt="The ChatGPT project menu with a New project option" width="636" height="358" data-path="images/box-drive/options.png" />
3. Add a new source folder to the project.
4. In Finder, locate your *Acme* folder in Box Drive, then select **Open**.
5. With the folder loaded, select **Create project**.
Your Box Drive folder is now the directory the project works from.
  <img src="https://mintcdn.com/product-docs/btkdJYIDqx2Q38jk/images/box-drive/chatgpt-window.png?fit=max&auto=format&n=btkdJYIDqx2Q38jk&q=85&s=a6ed1dd582454bb22d50bd398951e67e" alt="The ChatGPT composer showing the Acme folder attached to the project" width="972" height="228" data-path="images/box-drive/chatgpt-window.png" />
### Claude Cowork
1. Launch Claude, then select **Work in a project or folder**.
  <img src="https://mintcdn.com/product-docs/btkdJYIDqx2Q38jk/images/box-drive/claude-window.png?fit=max&auto=format&n=btkdJYIDqx2Q38jk&q=85&s=30da43ea05b07d510b079332b2292c4d" alt="The Claude Cowork start screen with the Work in a project or folder option below the message box" width="1023" height="396" data-path="images/box-drive/claude-window.png" />
2. In Finder, locate your *Acme* folder in Box Drive, then select **Open**.
Your *Acme* folder is now referenced in Cowork.
### Cursor
1. In Cursor, select the repository menu, which reads **No Repo** when no folder is selected.
  <img src="https://mintcdn.com/product-docs/7_nzZaLyTjJmOCwG/images/box-drive/cursor-window.png?fit=max&auto=format&n=7_nzZaLyTjJmOCwG&q=85&s=a65975f5c33bd9aa5d85df9f37cb889c" alt="The Cursor composer with the repository menu set to No Repo" width="863" height="263" data-path="images/box-drive/cursor-window.png" />
2. If your folder is not in the list of recent repositories, select **Use Existing…** > **Open Folder**.
  <img src="https://mintcdn.com/product-docs/7_nzZaLyTjJmOCwG/images/box-drive/cursor-window-open.png?fit=max&auto=format&n=7_nzZaLyTjJmOCwG&q=85&s=1a454ec3d19fbaa210fb8a8490fb7ff9" alt="The Cursor repository menu with Use Existing highlighted and an Open Folder option in the submenu" width="980" height="290" data-path="images/box-drive/cursor-window-open.png" />
3. Locate your *Acme* folder in Box Drive, then select **Open**.
Your folder is now the working repository for the session.
  <img src="https://mintcdn.com/product-docs/7_nzZaLyTjJmOCwG/images/box-drive/cursor-window-folder-selected.png?fit=max&auto=format&n=7_nzZaLyTjJmOCwG&q=85&s=ff47d0b66c54a0d68903d80776ee4fdf" alt="The Cursor composer with the repository menu set to the Acme folder" width="948" height="273" data-path="images/box-drive/cursor-window-folder-selected.png" />
  An AI app reads only the folder you point it at. To change its scope, select a different Box Drive folder.
## Connecting an AI app directly to Box Drive
For users with the respective AI agent already on their desktop, Box Drive also supports the ability to send specific folders and files straight to these agents from the context menu.
Users can right-click on the file or folder of their choice, and select one of the **Open with \_ \_ \_ \_** options available to them. This option will set the selected file or folder as the context right in the agent.
## Connecting directly to Box
Box Drive syncs your files to Box, where they are stored in the cloud and covered by Box security and compliance protections. For more on those protections, see the [Box Trust Center](https://www.box.com/trust).
Box supports three integration types for connecting an app directly to Box:
* AI Search
* AI Indexing
* Box MCP Server
To set one up, see [About Box MCP Server](/en/box-mcp/about-box-mcp-server) or the Box Support article on [connecting to Box from third-party AI apps](https://support.box.com/hc/en-us/articles/48273464323987-Connecting-to-Box-from-Third-Party-AI-Apps).
## What's next
With your agent(s) having access to your Box Drive directory, it can use all the content you have uploaded onto Drive as its context. This unlocks various agentic workflows. You can ask your agent a question or have it start a new PowerPoint, all underpinned by your files as context.
