# Creating and Sharing Box Canvas
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "End User , Overview , Box Canvas , Article , New , Product Utilization , P2"}} />
From the web app, create a Canvas by
* Clicking the + icon next to Box Canvas from the left side menu or
* Clicking New + on the home page and selecting Canvas.
Additionally, if you want to create another Canvas while on the current canvas, click the ellipsis dots at the top right top corner of the page and select New Canvas.
After creating a Canvas, the file is automatically titled "Canvas \{YYYY-MM-DD HH:MM:SS].boxcanvas”. If you create your first Canvas by either clicking on the Box Canvas + left navigation menu or the ellipses of an existing Canvas, a new folder is automatically created for you named "My Canvases". Any new Canvases created this way are stored in the "My Canvases" default folder. You can view the folder by clicking on the back button at the top left corner of the page.
  **Note:** If your company restricts content creation in the top level folder, then instead of having your first Canvas saved in the default folder "My Canvases”, you will be prompted to select a default folder to save your new Canvases that are created from the Box Canvas + left navigation menu or from the ellipses of an existing Canvas file.
## Sharing
To share your Canvas, click the **Share** button in the top right corner of your screen. You can share Canvas as other Box files - by inviting collaborators or creating a shared link and choosing a specific level of access for each option.
  <img src="https://mintcdn.com/product-docs/DTOHMH05H6pIRQke/images/box-canvas/screenshot-2023-03-29-at-19-04-37.png?fit=max&auto=format&n=DTOHMH05H6pIRQke&q=85&s=dca329a004e49017bc26fce0950ac548" alt="screenshot-2023-03-29-at-19-04-37-png" width="469" height="405" data-path="images/box-canvas/screenshot-2023-03-29-at-19-04-37.png" />
## Exporting Canvas
Export your Canvas to a .PNG file to share in an email or upload it to other applications.
To export your Canvas:
1. Open the **More Options** menu.
2. Select **Export** from the dropdown list.
     <img src="https://mintcdn.com/product-docs/DTOHMH05H6pIRQke/images/box-canvas/the-more-options-menu.png?fit=max&auto=format&n=DTOHMH05H6pIRQke&q=85&s=c4cfcbaf5e6818ba3fdaff86f0eb1e26" alt="the-more-options-menu" width="658" height="620" data-path="images/box-canvas/the-more-options-menu.png" />
3. Select the area you want to export. By default, all contents of your Canvas are selected, but you can crop it to include only some parts or expand to include the whole Canvas.
     <img src="https://mintcdn.com/product-docs/DTOHMH05H6pIRQke/images/box-canvas/part-of-canvas-selected.png?fit=max&auto=format&n=DTOHMH05H6pIRQke&q=85&s=03001864dec867948dcf9e12f058dd62" alt="part-of-canvas-selected" width="1600" height="1408" data-path="images/box-canvas/part-of-canvas-selected.png" />
4. Click **Export PNG** to save your selection.
