# Using templates in Canvas
    display: "inline-block",
    verticalAlign: "middle",
    height: height,
    width: "auto",
    margin: "0"
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "End User , Instructions , Box Canvas , Established , P1"}} />
Box Canvas templates help to organize content on your Canvas, without manually adding each object.
## Template picker
To open the template picker in Canvas, click the templates icon <InlineImage src="/images/box-canvas/box-canvas-templates-help-organize.png" alt="The templates icon in the Box Canvas toolbar used to open the template picker." /> in the Canvas toolbar.
The template picker displays pre-filled, available templates assigned to their respective categories, for example: mind map (brainstorming), two truths and a lie (icebreaker), RACI chart (business).
Each template tile shows its name, layout, and category it is assigned to.
  <img src="https://mintcdn.com/product-docs/SQsI2NgHXG0tSLSJ/images/box-canvas/each-template-tile-its-name.png?fit=max&auto=format&n=SQsI2NgHXG0tSLSJ&q=85&s=a3a1e724fbc21eb96312b998a854a35b" alt="The Canvas Templates picker showing Mind Map and Good, Bad, Start, Stop Retrospective tiles with their category labels." width="513" height="426" data-path="images/box-canvas/each-template-tile-its-name.png" />
When you click on the template you want to use, a modal with detailed description of the template and its layout appears. To go back to the template picker, click the arrow in the top left corner of the modal. To insert the selected template, click **Insert Template**.
