# Configuring Box Canvas
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "Overview , Admin , Box Canvas , Article , Established , Rollout , P1"}} />
As a Box Admin, you can enable or disable [Box Canvas](http://www.box.com/canvas) for all your managed or selected users and groups.
<h2 id="enabling-canvas">
  Enabling Canvas
</h2>
To configure Box Canvas, open the admin console and navigate to **Enterprise Settings** → **Content and Sharing**. Scroll down to the **Canvas** section.
There are four configuration options available for Canvas:
* Disable for all managed users,
* Enable for all managed users,
* Enable for select users and groups,
* Enable for everyone except select users and groups.
  <img src="https://mintcdn.com/product-docs/DTOHMH05H6pIRQke/images/box-canvas/canvas-configuration.png?fit=max&auto=format&n=DTOHMH05H6pIRQke&q=85&s=ab758b7a027bd0ff97a7bc354e66a389" alt="canvas-configuration-png" width="476" height="360" data-path="images/box-canvas/canvas-configuration.png" />
Pick the option that suits your needs the most and save your changes. After saving, the option you chose is displayed next to the **Canvas** section in the admin console.
  <img src="https://mintcdn.com/product-docs/DTOHMH05H6pIRQke/images/box-canvas/image-2023-04-19-11-04-00-098.png?fit=max&auto=format&n=DTOHMH05H6pIRQke&q=85&s=4ec77cf6ee3d49f7622bdf5230748bd9" alt="image-2023-04-19-11-04-00-098-png" width="586" height="251" data-path="images/box-canvas/image-2023-04-19-11-04-00-098.png" />
You can change the configuration in the same section if necessary.
  **Note**:\
  Enabling Box Canvas for specific users has the following limitations: You can enter up to 100 names/email addresses and up to 100 groups. If you want to enable or disable more, you have to enable or disable Canvas for the entire organization.
