# Enabling Box Automate
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "Admin , Established , P1 , Box Automate"}} />
Box Automate streamlines business processes through automated workflows. This guide provides administrators and co-admins with the necessary steps to enable, govern, and delegate workflow management across the enterprise.
## Managing Box Automate access
To manage Box Automate for end users, admin must configure the enablement settings within the Admin Console.
### Configuring Box Automate
1. Navigate to the **Admin Console** > **Enterprise Settings**.
2. Select the **Content & Sharing** tab.
3. Scroll to the **Box Automate** section.
4. Click **Edit configuration**.
5. Under **User Access:**
   * **Enable** for all users
   * **Disable** for all
   * **Enable** for some users
   * **Disable** for some users
6. Click **Save** to apply changes.
  **Note:**
  * Disabling Box Automate at the enterprise level will immediately pause all active workflows. Use caution when modifying global enablement settings.
  * The setting within Admin Console - Content & Sharing labeled Prevent collaborators from moving or copying content to a folder where they have a higher permission level is not applicable to actions performed by Automate Workflows executions.
## Governance and security considerations
Administrators can maintain robust oversight of automated workflows to ensure security and compliance standards are met.
### Access and approval controls
* **User Access Management**: Use the allowlist settings in Enterprise Settings to ensure only authorized personnel or specific departments can build automations.
### Monitoring enterprise activity
Once permissions are granted, co-admins can access the **Automate** tab to monitor the status of all enterprise workflows.
