# About Box Automate
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "End User , Automate process , Overview , Article , Product Utilization , Established"}} />
Box Automate is an agentic workflow automation solution built natively on the Box content platform. It provides a drag-and-drop visual builder with parallel and conditional branch routing, logic, loops, and a comprehensive set of triggers and outcomes to power business process automation.
Box Automate integrates natively with Box AI, Box Extract, Box Forms, Box Doc Gen, Box Hubs, and Box Sign. Depending on your plan, you can build end-to-end content workflows that span document generation, e-signatures, AI-driven metadata extraction, and multi-stage approvals within a single platform.
## Visual workflow builder
You can build workflows using a visual builder that supports a robust set of triggers, conditional branch routing, parallel and merge branches, loops, dynamic variables, and agentic steps.
## Triggers
Triggers define what starts a workflow. Supported types include:
* File or folder events
* Task completion or status changes
* File Request
* Metadata Events
* Form submissions
* Manual start
* Sign events
* Schedule trigger
## Outcomes
Outcomes define what happens when a workflow runs:
* **File and folder actions** — move, rename, copy files, or create folder structures
* **Metadata actions\*** — apply, update, or extract metadata using AI
* **Task and notification actions** — assign approval or general tasks and send email notifications
* **Box Doc Gen\*\*** — generate documents from templates
* **Box Sign\*\*** — route documents for e-signature
* **AI Agent outcomes\*\*** — run custom AI agents or Box Extract agents for metadata extraction at scale
* **Multi-agent orchestration** — coordinate multiple AI agents in a single workflow
* **HTTPS Request\*\*** — call external APIs directly from a workflow
\* Enterprise / Enterprise Plus
\*\* Enterprise Advanced only
## Agentic AI
Box Automate brings AI directly into your workflows with AI agents, automated metadata extraction, AI-based routing, human-in-the-loop validation, and continual learning that adapts to new document formats over time. Including an approval task to review AI outcomes can help ensure accuracy.
  Querying AI agents inside Automate workflows is charged against AI units. Contact your Box administrator to check your AI usage limit.
## Collaboration and administration
You can share workflows with role-based permissions and track workflow runs.
## Integrations
Box Automate connects natively with Box Forms, Box Doc Gen, Box Sign, Box Extract, Box Hubs, Box AI Studio, and Box Apps.
| Use case | Description |
| Procurement | Vendor data is posted to Box, where an AI extraction agent pulls key metadata. An employee reviews the extracted values, and a purchase order is generated using Box Doc Gen. |
| Employee onboarding | New employees upload required documents such as a driver's license or I-9 form to Box. An AI agent supports validation of the documents, expiration dates are tracked as metadata, and notifications are sent automatically before documents expire. |
| Multi-stage approvals | Teams create SOPs or marketing materials and route them through multi-stage approval workflows. Approvers receive tasks with approval or rejection options, and the workflow branches based on each decision. |
| Financial document intake | A finance team submits documents via a file request. Box Automate renames, tags, and moves each file into the appropriate folder based on metadata such as store number or account. |
| Tax return data extraction | Financial documents are received weekly. Box Extract pulls key fields such as amount payable, refundable amount, and financial year. Emails are auto-generated for admin review. |
| Loan and lease processing | A new opportunity is opened and a document is uploaded to Box. AI extracts metadata, an employee verifies accuracy, and the extracted metadata updates the corresponding record. |
| Project management | A new project is added to the roadmap and relevant documents are uploaded to Box. The workflow creates a Jira ticket linked to the Box file and notifies stakeholders. |
| Scientific publications management | Research institutions ingest, manage, route, and secure publication records and technical reports across workflows and external reporting endpoints. |
## Known limitations
Templates are not available for Box Automate.
### Classification
If the classification policy set within the Admin Console restricts **Apply Classification** to the Owner role, all Apply Classification outcomes in Automate workflows are blocked from running.
### Workflow runs
* Max 10 branches (including ELSE) and max 20 conditions per IF are supported.
* Workflow deactivation does not terminate workflows that are already in progress.
* The Agent outcome works only when a File/Folder ID is referenced, not the name.
* When the folder or enterprise setting is **Only folder owners and co-owners can send collaborator invites**, the following outcomes fail:
  * **Task Assignment**
  * **Add/Remove Collaborator**
  * **Lock** and **Unlock**
  * **Move**, **Copy**, and **Create folder** operations
  * **Apply Classification** when the policy requires higher privileges
### Collaboration and permissions
* The Add/Remove Collaborator outcome does not support external email addresses and groups.
* Groups with permission type **Admin** and **Group members** are not yet supported in the outcome in Automate.
### Variables and metadata
* There is no support for metadata from Current Outcome. As a workaround, use a metadata variable without linking to an outcome ID.
* Hidden metadata templates are not supported in the Add Metadata outcome or metadata conditions.
* You cannot add all metadata form field values to created files or folders as metadata without mapping them individually.
### Box Sign integration
* Sign does not support tracking status via metadata for **in progress** status.
* The Sign outcome supports only signers from the email field in Forms, not from any text field.
* There is no File Name variable from the Sign outcome.
### Automate interoperability
* Automate workflows are not fully interoperable with Box features such as Information Barriers, Governance, Box Shield, Box Zones, and Box Keysafe.
* The **Move and copy content to a folder** control in the Admin Console (**Prevent collaborators from moving or copying content to a folder where they have a higher permission level**), as described in [Enterprise Settings: Content & Sharing tab](/en/box-admin-tools/box-admin-reference/enterprise-settings-content-sharing-tab#move-and-copy-content-to-a-folder), does not apply to Automate workflows. Moving or copying content into folders via an Automate workflow may still result in some users being granted a higher permission level. You can mitigate this by allowing users to create workflows only on folders where they have Owner or co-owner permission in Box Automate enablement settings.
