# Using Charts in Box Apps
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "End User , Box Apps"}} />
The **Chart** block allows you to create bar and donut charts based on the configuration details that you provide.
**To start working with charts:**
1. Select the **Grid** layout.
2. Add the **Chart** block.
3. Select the **Metadata Template** that you want to use.
4. Under **Setup**, select the **Attribute to Visualize** option.
Your chart renders.
You can also create a chart in the list view, but it shows as a table. To display it as a donut or bar chart, change the view to grid.
## Configuring a donut chart
Each segment of a donut chart is interactive. Hovering over it displays a hover card legend for that segment. Clicking it opens the **View** for that segment.
For a donut chart, you can:
* Add filters and columns by clicking the **Configure View** button.
* Select how many categories you want to display on your chart (max 8).
* Choose if you want to display the remaining categories as **Others**.
  **Note** \
  Each legend item is interactive. Clicking it opens the **View** of that value.
## Configuring a bar chart
For a bar chart, you can configure the same options as for a donut chart, and select the chart orientation: **Horizontal** or **Vertical**.
