# Using AutoFiler in Box Apps
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "End User , Article , Established , P3 , Box Apps"}} />
AutoFiler allows you to add Metadata to your files during the upload process.
When your files are uploading, you can add Metadata to it in the **Current File** tab. Select the **Metadata Template** from the drop-down list.
Other required fields depend on the metadata template your Box Admin created.
Click **Apply to All** - a **Confirm Apply To All** dialog appears with the following text:
**Applying these changes will apply the entered Metadata values to all remaining files.**
Click **Apply to All** again. You can also **Cancel** this action.
## Informational and error messages
File upload success message: **\[number] documents uploaded**.
File upload fail message: **\[number] upload failed**.
If you try to upload a file with the same name as another file in the folder, a following message appears: **Item failed to upload. Item with the same name already exists.**
For more information on metadata, see [Using Metadata](/en/box-fundamentals/for-users/staying-organized/organizing-and-tracking-content/using-metadata).
