# Viewing Organization Storage and Bandwidth Usage
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "storage , Admin"}} />
Tools in the Admin Console can help you understand how much storage your organization uses and how much bandwidth your organization consumes, which helps you comply with the [Box Fair Use Policy](https://www.box.com/en-gb/legal/fairusepolicy).
* For high-level information, go to **Admin Console > Account and Billing**. In the Usage section, you will see:
  * The total amount of storage your organization uses currently, and, if your organization has a limit on the total amount of storage it is allowed to use, that amount also. (This allows you to see if you are approaching your limit; you can reach out to your support representative if you require a higher limit.)
  * The amount of upload bandwidth, download bandwidth, and total bandwidth consumed by your organization during the current calendar month.
* For details about the storage your organization uses, go to **Admin Console > Insights** and view the [Storage](/en/box-admin-tools/reporting-and-insights/admin-insights-data-tiles#storage) tile.
* For details about the bandwidth your organization consumes, go to **Admin Console > Reports** and run a [Bandwidth Usage by User](/en/box-admin-tools/reporting-and-insights/bandwidth-usage-by-user-report) or a [Bandwidth Usage by Files and Folders](/en/box-admin-tools/reporting-and-insights/bandwidth-usage-by-files-and-folders-report) report.
