# Editing an Existing Automation
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "Automations , Admin , Admins , Article , New , Product Utilization , Instruction"}} />
<Warning>
  **Important**
  Box Automations is a legacy Box feature. Box released a re-architected and significantly enhanced Box Relay in June, 2019, which is more powerful and includes a much larger range of trigger and output events, including files, folders, tasks, metadata, and more, and we recommend all Automations users transition to Box Relay for any workflow needs.
</Warning>
## To edit any of your existing automated processes:
1. From the Admin Console, in the lefthand navigation, click **Content**.
2. Toward the top of the page, click **Automation**.
3. From the list on the left, select the automation you want to edit.
4. Enter your changes.
5. Click **Update Automation**.
Your changes go into effect immediately.
  <img src="https://mintcdn.com/product-docs/58cy48joLTunkOvM/images/box-admin-tools/fetmdpfxunfpjsitahsp.png?fit=max&auto=format&n=58cy48joLTunkOvM&q=85&s=7233ccd026ca68d3983857745fc1d7b3" alt="" width="1154" height="768" data-path="images/box-admin-tools/fetmdpfxunfpjsitahsp.png" />
