# Configuring A Firewall For Box Applications and Services
export const TranslatableCodeBlock = ({children, lang = "auto", language, ...props}) => {
  const raw = Array.isArray(children) ? children.join("") : String(children ?? "");
  const lines = raw.split("\n");
  const indent = Math.min(...lines.filter(line => line.trim() !== "").map(line => line.match(/^[ \t]*/)[0].length));
  const code = lines.map(line => line.slice(indent)).join("\n").replaceAll("<i18n>", "").replaceAll("</i18n>", "");
  const resolvedLanguage = language ?? lang;
  return <CodeBlock language={resolvedLanguage} {...props}>{code}</CodeBlock>;
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "Admin , Product Utilization , Instruction"}} />
A firewall is a part of network security that controls which network traffic can enter or leave your business. Firewalls can be set to block all traffic, allow or block specific types, or permit all traffic. In most cases, a firewall is set up to allow traffic through specific ports unless explicitly blocked, or for more stringent security measures, to block traffic unless explicitly allowed.
Firewalls are configured to allow or block traffic in several ways, including by geographic source, by port, by domain/hostname, and by IP address. Box and Box applications require the traffic to and from specifically defined domains to be allowed through a corporate or personal firewall, as outlined in this topic.
Typically, you would include these domains/hostnames in your firewall's allowlist. Please refer to the instructions for your particular firewall hardware or software for details.
## 1. Firewall Allowlist Domains/Hostnames
Here are the domains/hostnames that need to be allowlisted for Box and its applications, integrations, and components to work correctly. Box will notify you of any changes in this list through [product announcements](/en/announcements). Box recommends regularly checking this page to stay updated. It is important to update your firewall whenever there are any changes.
Configure firewall allowlist with any **subdomain** and **Hosts** of **Box Core domains** and **any other related services.**
### 1a. Box Core Domains
  **Note:**
  Best practice is to use our site's **domain names** instead of a particular site IP address. IP addresses can change frequently and without notice.
Configure hostnames to recognize any subdomain of:
<TranslatableCodeBlock lang="auto">
    *.box.com
    *.app.box.com
    *.ent.box.com   # <i18n>"ent" only required if you are a Box Verified Enterprise account</i18n>
    *.box.net
    *.boxcdn.net
    *.boxcloud.com
    *.services.box.com
</TranslatableCodeBlock>
### 1b. Other related service Domains/Hosts
    # <i18n>Box Test</i18n>
    *.box-test.com
    # <i18n>Box for Microsoft Teams</i18n>
    app.boxenterprise.net
    cdn.jsdelivr.net
    unpkg.com
    # <i18n>Box Sign</i18n>
    fonts.gstatic.com
    fonts.googleapis.com
    # <i18n>Box Support Site and Product Documentation</i18n>
    support.box.com
    docs.box.com
    leaves.mintlify.com
    hcaptcha.com
    *.hcaptcha.com
    # <i18n>To log in to our support site to submit a support ticket you must allow:</i18n>
    box.zendesk.com
    support.box.com
    # <i18n>For all other inbound traffic, you must allow the list of ingress and egress IP addresses found at the following:</i18n>
    https://support.box.com/ips
    # <i18n>The URL doesn’t require authentication. You can copy this URL and paste it into the address bar of any browser. </i18n>
    # <i18n>You may want to set up a scheduled request periodically to determine if the IP addresses listed in the request response change.</i18n>
    # <i18n>Box Education</i18n>
    *.brightcove.com
    *.brightcove.services
    *.zencdn.net
    *.boltdns.net
    *.akamaihd.net
    *.yext.com
    training.box.com
    # <i18n>Box Web Analytics</i18n>
    # <i18n>No personally identifiable information will be collected. Any data collected is anonymous. See Box Analytics Product Announcement for more details.</i18n>
    *.demdex.net
**Other integrations:**
* **Box for Office Integration**: To use the [Box for Office Online integration](https://support.box.com/hc/en-us/articles/360044196433-Box-for-Office-Integrations#bfo_officeonline) and [Excel Online Previewer](https://support.box.com/hc/en-us/articles/360043695314-Excel-Online-Previewer), allow [Office 365 URLs and IP address ranges](https://docs.microsoft.com/en-us/office365/enterprise/urls-and-ip-address-ranges?redirectSourcePath=%252fen-gb%252farticle%252foffice-365-urls-and-ip-address-ranges-8548a211-3fe7-47cb-abb1-355ea5aa88a2).
* **Box for Google Workspace**: To use the [Box for Google Workspace](https://support.box.com/hc/en-us/articles/360043696994-Introducing-Box-for-G-Suite), please go to [the Google support pages](https://support.google.com/a/answer/2589954) for the hostnames you must allow. (You can ignore the Google Drive/drive IP addresses because this Box integration does not have a dependency on Google Drive.)
* **Box for iWork Integration**: To use the [Box for iWork integration](https://support.box.com/hc/en-us/articles/360043696654-iWork-Integration), you must allow access to Apple’s network at `17.0.0.0/8`
* Optionally, if using an IP allowlist, be sure to allow the IPs listed on [https://www.cloudflare.com/ips/](https://www.cloudflare.com/ips/)
<Warning>
  **IMPORTANT:**
  If above Domains / Host names are not allowed, related functions or services will not work. Use the section below.
</Warning>
### 1c. Specific hostnames
If you cannot allow the wildcard domains shown in the two lists above, allow these **specific hostnames:**
    # <i18n>Box core features</i18n>
    2.realtime.services.box.net
    account.box.com
    api.box.com
    app.box.com
    ent.box.com
    captcha.boxcdn.net
    cdn01.boxcdn.net - cdn20.boxcdn.net
    client-log.box.com
    developer.box.com
    dl.boxcloud.com
    dl2.boxcloud.com - dl20.boxcloud.com
    public.boxcloud.com
    docs.box.com
    e3.boxcdn.net
    newassets-captcha.boxcdn.net
    notes.services.box.com
    rtg.services.box.com
    sso.services.box.net
    support.box.com
    track.box.com
    upload.app.box.com
    upload.ent.box.com
    upload.box.com
    upload.box.net
    {yourcustomsubdomain}.account.box.com
    {yourcustomsubdomain}.app.box.com
    {yourcustomsubdomain}.box.com
    {yourcustomsubdomain}.ent.box.com
    unpkg.com
    cdn.jsdelivr.net
    # <i18n>Box Captcha feature (used at login), you must allow the following: </i18n>
    captcha.boxcdn.net
    images-captcha.boxcdn.net
    reportapi-captcha.boxcdn.net
    fonts.gstatic.com
    box.zendesk.com
    support.box.com
    docs.box.com
    leaves.mintlify.com
    hcaptcha.com
    *.hcaptcha.com
    edge.api.brightcove.com
    gallery.assets.brightcove.com
    interactivity-collector.metric.brightcove.com
    interactivity.viewer.api.brightcove.com
    metrics.brightcove.com
    player.interactivity.brightcove.com
    players.brightcove.net
    cdn.vee.brightcove.services
    reflector.brightcove.services
    resources.interactivity.brightcove.com
    simulive-license-service.brightcove.services
    vjs.zencdn.net
    cf-images.us-east-1.prod.boltdns.net
    cbolt446c5271-a.akamaihd.net
    training.box.com
    liveapi-cached.yext.com
    liveapi.yext.com
    realtimeanalytics.yext.com
    sanalytics.box.com
    box.demdex.net
    dpm.demdex.net
    pendo-data-prod.box.com
    pendo-prod.box.com
    # <i18n>Box SFTP</i18n>
    sftp.services.box.com
    # <i18n>Box SFTP for Zones</i18n>
    sftp-ane1.services.box.com
    sftp-ausse1.services.box.com
    sftp-euw2.services.box.com
    sftp-euw3.services.box.com
    box-test.com
    # <i18n>Box Zones</i18n>
    upload.app.box.com
    upload.ent.box.com
    dl.boxcloud.com
    fupload-nane1.app.box.com
    fupload-nane1.ent.box.com
    nane1.boxcloud.com
    fupload-euw2.app.box.com
    fupload-euw2.ent.box.com
    euw2.boxcloud.com
    fupload-euc1.app.box.com
    fupload-euc1.ent.box.com
    euc1.boxcloud.com
    fupload-ane1.app.box.com
    fupload-ane1.ent.box.com
    ane1.boxcloud.com
    fupload-ause1.app.box.com
    fupload-ause1.ent.box.com
    ause1.boxcloud.com
    # <i18n>AWS Marketplace Purchases</i18n>
    fupload-usw1.app.box.com
    fupload-usw1.ent.box.com
    usw1.boxcloud.com
    # <i18n>Box Website, Community, Blog, and Service Status</i18n>
    assets.box.com
    www.box.com
    www.box.net
    status.box.com
    blog.box.com
    community.box.com
**Other integrations**
* **Box for Office Integration:** To use the [Box for Office Online integration](https://support.box.com/hc/en-us/articles/360044196433-Box-for-Office-Integrations#bfo_officeonline) and [Excel Online Previewer](https://support.box.com/hc/en-us/articles/360043695314-Excel-Online-Previewer), allow [Office 365 URLs and IP address ranges](https://docs.microsoft.com/en-us/office365/enterprise/urls-and-ip-address-ranges?redirectSourcePath=%252fen-gb%252farticle%252foffice-365-urls-and-ip-address-ranges-8548a211-3fe7-47cb-abb1-355ea5aa88a2).
* **Box for Google Workspace:** To use the [Box for Google Workspace](https://support.box.com/hc/en-us/articles/360043696994-Introducing-Box-for-G-Suite), please go to [the Google support pages](https://support.google.com/a/answer/2589954) for the hostnames you must allow. (You can ignore the Google Drive/drive IP addresses because this Box integration does not have a dependency on Google Drive.)
* **Box for iWork Integration:** To use the [Box for iWork integration](https://support.box.com/hc/en-us/articles/360043696654-iWork-Integration), you must allow access to Apple’s network at `17.0.0.0/8`
<Warning>
  **IMPORTANT:**
</Warning>
## 2. Port and connection details:
Enable **HTTPS port 443 TCP** for the domains above, and allow Web Socket protocol **wss\://**.\
To connect with **HTTP/3 (QUIC)**, Box recommends you also optionally enable **port 443 UDP**.
  **Note:**
  Box is integrating [ZSTD](https://facebook.github.io/zstd/) (Zstandard) compression ([rfc8878](https://www.rfc-editor.org/rfc/rfc8878)) to improve performance and reduce bandwidth usage when supported by the client's browser (see [Product Announcement](/en/announcements/uploads-and-downloads/performance-enhancements-with-zstd-compression)). ZSTD is a lossless data compression technique that accelerates page loading from Box. By default, the browsers Chrome, Edge, Firefox, and Opera enable ZSTD compression. It is important to be aware that ZSTD previously encountered compatibility issues with FortiGate and Zscaler but are now resolved. Although unlikely, other firewalls that perform *deep packet inspection* (DPI) may encounter issues with Box's ZSTD implementation. To ensure optimal functionality, we recommend that network administrators either upgrade their firewall/proxy systems to versions that support ZSTD compression, or to disable HTTPS packet inspection in your firewall/proxy for the domains `*.box.com` and `*.boxcloud.com` . Making these changes will help maintain the integrity and efficiency of data transfers.
Alternatively, ZSTD Content-Encoding support may be disabled directly in a browser but this may lead to decreased performance on all sites using ZSTD:
* **Chrome**: Visit [https://chromeenterprise.google/policies/#ZstdContentEncodingEnabled](https://chromeenterprise.google/policies/#ZstdContentEncodingEnabled)
* **Edge**: Visit [https://learn.microsoft.com/en-us/deployedge/microsoft-edge-policies?source=recommendations#zstdcontentencodingenabled](https://learn.microsoft.com/en-us/deployedge/microsoft-edge-policies?source=recommendations#zstdcontentencodingenabled)
* **Opera**: Visit `opera://flags/#enable-zstd-content-encoding` and change to Disabled
* **Firefox**: Visit `about:config`
  * Paste the following string into the top field: `network.http.accept-encoding.secure`
  * Edit the value field to remove `zstd`
  * The value field should show `gzip, deflate, br` after your edit.
If you need further assistance, please [contact Box Product Support](https://support.box.com/hc/en-us/requests/new).
## 3. Box Desktop Applications' Proxy Support
Box Drive, Box Sync, Box Tools, and Box for Office are desktop applications that must connect to Box's data centers to function. The apps utilize the same domains outlined above. The apps detect and use the proxy configured for the local machine via:
* Automatic Proxy Detection
* Proxy Auto-Configuration (PAC file)
  * Windows does not support local file path schemas for the .pac file location such as `file://C:\proxy.pac`\
    Use a URL to configure the .pac file location.
* Or manually setting the proxy server address for **HTTPS** protocols
For proxy authentication support:
* Windows apps support NTLMv1 or NTLMv2 authentication
  * Box for Office, Box Tools (machine-wide build), and Box Sync use a Windows Service that needs to connect to Box's data centers to check for new versions. The Windows Services run as the SYSTEM user, which may be unable to authenticate using NTLM. We recommend allowing SYSTEM run Services to connect through your proxy without authentication.
* Mac apps support NTLMv1 authentication only.
* HTTP Basic authentication (BA) is not supported.
## 4. Testing Connectivity to Box Domains
To test whether your browser can connect to various Box domains, go to our [**Connectivity Testing**](https://support.box.com/hc/en-us/articles/360043694474-Box-Connectivity-Tests) page. Each test image is hosted on a different Box URL.
## 5. Configuring Email for Box Notifications
Box uses an email service provider to deliver notification messages, such as invitations to collaborate on content when a file has been shared. To ensure your organization can receive notifications from Box, you may need to update your filters to allow email notifications to reach your users. Read [Configuring Email for Box Notifications](/en/box-fundamentals/for-users/user-login-and-settings/configuring-email-for-box-notifications) for more details.
