# Enterprise Settings: User Settings Tab
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "User Management , Admin , Article , New , Product Utilization , Announcement"}} />
User settings define default settings for new managed users as well as configure several other user options. This topic contains the following sections:
<h2 id="expire-join-invites">
  Expire Join Invites
</h2>
This setting defines expiration dates for invites.
### **Invites to join expire after**
Defines an organization-wide time period after which invitations to join the organization expire. In general, a shorter duration improves security. Select from:
* 1 year (default)
* 6 months
* 1 month
* 7 days
* 72 hours
* 24 hours
If this setting is changed, the change applies to all invites that have not been accepted. If someone has received multiple invites, they all are subject to the value in this setting.
<h2 id="user-submitted-text-feedback">
  User-Submitted Text Feedback
</h2>
This setting controls whether users can provide written (text) feedback in Box.
If the **User-Submitted Text Feedback** setting is enabled, users may see an open-text field where they can share more detailed input. If the setting is disabled, only structured feedback (for example, multiple-choice options) will be collected.
For example, when a user interacts with certain in-product prompts - such as rating an experience with a thumbs down - the feedback process may include this open-text option when the setting is enabled.
<h2 id="name-change-restrictions">
  Name Change Restrictions
</h2>
This setting can enhance the security of user accounts, preventing bad actors from spoofing identities. For example, a user entering the CEOs name in their Account Settings. Box uses the information entered in the account's Your Name field when searching for people, in @ mentions, and more.
### User name
Restricts all managed users from changing their name as entered in the Your Name field in their Account Settings. An Admin will be required to change that value for any user.
  **Note**
  When enabled, this setting does not prevent integrated identity providers, such as Microsoft Azure AD or Okta, that manage Name information from changing the Name value when it is changed in the integration.
## New User Default Settings
These settings define how new managed user accounts are configured. Changes to these settings do not get applied to existing managed user accounts.
### **Enable Box Sync**
Enables users to synchronize files between Box and their computer hard drive via [Box Sync](/en/box-sync/using-box-sync/about-box-sync).
### **Shared contacts**
Allows users to access all other managed users in their contacts list when inviting collaborators. External users will not be accessible unless already collaborating. If you clear this setting, users will access only the people they are actively collaborating with and will need to manually fill the contacts list.
### **Device pinning**
Enables users to be exempt from the maximum number of devices synchronized with their Box account value set for your enterprise in Enterprise Settings > Device Pinning.
### **Restrict external collaboration**
Restricts users from creating external collaborations for folders they own.
### **Storage allocation (GB)**
Defines the total amount of storage, in gigabytes (GB), users are allocated in your Box organization. Enter a number or select the Unlimited check box.
"Unlimited" is defined as up to the amount your enterprise subscription level contains.
### **Time Zone**
Defines the time zone of where the user is located. Used to determine the correct date and time for user activities.
The user can also change the value of this setting on their own Account Settings page.
### **Language**
Defines the language the user will see in the Box user interface when signed in.
<h2 id="configure-single-sign-on-sso-for-all-users">
  Configure Single Sign-On (SSO) for All Users
</h2>
This setting determines whether you have single sign-on (SSO) configured for your users, and if so, determines how it is configured. See [Setting Up Single Sign-On (SSO) for Your Enterprise](/en/box-admin-tools/box-security/setting-up-single-sign-on-sso-for-your-organization) for details.
<h2 id="enable-single-sign-on-sso-for-all-users">
  Enable Single Sign-On (SSO) for All Users
</h2>
This section is available only if you have SSO configured in the *Configure Single Sign-On (SSO) for All Users* section.
### SSO Test Mode
Enables SSO for all managed users in your organization, but also allows those users to login with their username and password if they have issues with SSO.
Enable this option only after initially configuring or changing SSO so you can test SSO within your organization and confirm that it is configured correctly.
<h3 id="sso-required">
  SSO Required
</h3>
Enables SSO for all managed users within your organization and requires its use.
Enable this option only after sufficient test time in SSO Test Mode when you are sure SSO is configured and operating correctly.
<Warning>
  **Important**
  * For security reasons, enabling *SSO Required* is considered a "critical action" and requires multi-factor authentication (MFA) to complete.
  * Be sure you have tested the SSO login flow before enabling this setting. If you do not test that your SSO credentials are working correctly, you could be locked out of your Box account.
</Warning>
## Diagnostic Settings
This setting determines if users can grant (limited) access for Box Support for troubleshooting. Granting access for Box Support is available for Business plans and above.
