# Enterprise Settings: Notifications Tab
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "Admin Console , Notifications , Admin"}} />
Enterprise settings define how Box works in your organization, and the settings in the Notifications tab define settings for how Admins and users can receive Box notifications. This topic contains the following sections:
## Email Notifications Section
This section defines the default notification settings for managed users within your organization. Users will be able to [change from default settings from their Account Settings page](/en/box-fundamentals/for-users/user-login-and-settings/manage-account-settings#email-notifications).
### Default Email Notifications
Determines which event-based email notification settings are enabled by default for new managed users. For both folders users own and folders user have joined (as a collaborator), they can get notified for:
* Downloads
* Uploads
* Comments
* Previews
* Deletes
When enabled, these notifications will trigger when any of these events happen for any content in a user's owned or collaborated folder.
The notifications that are enabled by default in the Admin Console are:
* Downloads for joined folders
* Comments for owned folders
* Deletes for owned folders
### Disable email notifications for all users in your enterprise and all of their content
Determines if content-based email notifications are disabled. If disabled, email notifications will not be sent to managed users or any collaborators on the users' content, including the daily digest. (Direct emails, such as tasks and invitations, will still be sent.) Select from:
* Enabled - Means that email notifications are disabled, and no content-based email notifications are sent to any user, regardless of administrator or user settings.
* Disabled (default) - Means the email notifications are enabled, and content-based email notifications are sent according to administrative and user settings.
### Allow all users to receive Box notifications at an alternate notification email address
Determines if email notifications are sent to a user's primary or alternate email address. By default, notifications are sent to a users' primary email address. Select from:
* Enabled (default) - Allows users to set up and use an alternate email address to receive notifications.
* Disabled - Prevents users from receving notifications at an alternate email address. All notificaitons will be sent to a user's primary email address.
### Allow all users to change their notification email
Available only if *Allow all users to receive Box notifications at an alternate notification email address* is enabled. Determines if users are allowed to change their alternate notification email address. Select from:
* Enabled (default) - Allows users to change their notification email address on their Account Settings page.
* Disabled - Prevents users from chaning their notificzaiton email address.
## Email Test Section
You may need to work with your organization's IT department to update your filters to allow email notifications to reach your users, depending on your organization's security and email configuration. This section allows you to test the email service provider partner that Box uses to deliver email notifications.
### Send Email Button
Click **Send Email** to confirm that email notifications can be successfully delivered to your organization. The email will be sent to the primary Admin email address.
## Email Settings Section
This section contains controls for whether or not notifications are sent for specific events.
### Send new login activity emails to users
Determines if users get notified each time they access their account from a new browser or application. Select from:
* Enabled (default) - New login activity email notifications get sent.
* Disabled - New login activity email notifications do not get sent.
### Send daily digest emails for login activity to the admin
Determines if the organization Admin receives a daily digest email summarizing the login activity of all users within the organizaiton. Select from:
* Enabled - The organizaiton Admin receives a daily digest email.
* Disabled (default) - The organizaiton Admin does not receive a daly digest email.
### Enable Silent Mode for your admin activity (does not apply to co-admins)
Determines if notifications that would be sent to users as a result of actions taken by the Primary Admin of the Box account are suppressed temporarily. This setting is available only to an organization's primary Admin and applies only to actions taken by the Admin via the Admin Console.
Primary Admins can use Silent Mode to provision new accounts, create Groups, and change Group access settings. Silent Mode acts as a holding pen, not a mute button. This means any notifications that have been queued up with Silent Mode enabled will be released to users' inboxes once Silent Mode is turned off. See [Using Silent Mode to Suppress User Notifications](/en/box-admin-tools/how-to-guides-for-admins/using-silent-mode-to-suppress-user-notifications) for more details. Select from:
* Enabled - Suppresses user notifications that would be sent to users as a result of actions taken by the primary Admin.
* Disabled (default) - Allows normal user notifications that would be sent to users as a result of actions taken by the primary Admin. If switched to Disabled from Enabled, releases and sends all notifications that were suppressed during the time that the setting was set to Enabled.
<h2 id="automatic-email-of-user-communication-section">
  Automatic Email of User Communication Section
</h2>
This section contains controls for receiving email notifications at a designated address about selected user activity.
### Activities
Determines which user activities that generate notification emails to users will also send hidden copies to the defined email address. Select from:
* Comments - includes both comments and replies on files and folders.
* Emails - includes internal and external collaborator invitations, shared link invitations, and emails sent to all collaborators using the *Mail All* option.
* Invitations - include sautomatically accepted invitations to collaborate in folders.
* Tasks - includes task assignments and responses to tasks.
### Copy of Communication
Available only when one or more Activity is enabled, defines where to send hidden copies of notification emails sent to users. Select from:
* Enabled - And then enter a (required) valid email address.
* Disabled (default) - Hidden copies of email notifications are not sent.
